Lattice structure minimum diameter
User: "Altair Forum User"
Updated by Altair Forum User
Hello
Normally a lattice optimization does create lattice structures of different elements. Does a way exist to set a minium diameter of the lattice structure?
I know the function 'MINRAD', which cleans in the second optimization phase and eliminates all elements above the set value. If I use MINRAD, almost all  lattice structures are eliminated, as they are quite small (between 0.0027 and 0.335 mm). The ideal lattice structure would have diameters above 0.5 or 1 mm. How can this be set?
I thank you in advance for your help!
1 - 4 of 41
    OP
    You can set a Maximum Radii using MAXRAD.
    I dont see a way for minimum radius, but I will check if there is a way to work it out.
    OP
    Hello
    Thank you!
    Well the minimum diameter is also related to the element size. I guess by setting a mesh with enough big elements, will create bigger lattice structures.
    OP
    How does the MINDIM work?
    I have changed the elment mesh size to 7.5 mm and set MINDIM to 0.5 mm. But I still get lattice structures with smaller diameters (Ømin=0.038 mm).
    OP
    I dont think MINDIM will help as MINDIM should be set to 3 times the element size.
    I will check with devs regarding the same and will let you know soon.
