Hi
I have two geometrically complex component which are in contact. The problem is that I can not see and determine which surfaces are touching each other due to complexity of two component. Is there any tool in Hypermesh to enable us to determine which surfaces are touching each other for instance shows the she surfaces in contact with another color? Thanks for your help in advance
