Submitted by John Haine on Tue, 03/15/2011 - 15:14
The Gaussian Noise block allows one to set the mean and standard deviation of the noise, but it isn't clear what the power spectral density should be. Can one assume for example that if the iteration time is 10 microseconds, the effective sampling rate is 100 kHz, and the noise bandwidth would be 50 kHz? Should one assume a flat spectrum up to that limit or a sinc spectrum?
Thanks, John.
