What is this error? How to resolve this?
This error usually appear when you reopen an Motion View file which including Altair Diriver or some parts in Wizard library. It is due to wrong selection in attachment for systes or assembly.
When I get this problem, I just ignore it and try run a test run. Usually, the problem will solve itself
When I get this problem ,I dont get any 'Add Events' option on right click on Model.So How to add Analysis like constant radius ,single lane change?
Does Student version of Hyperworks has license for Altair driver?
Hi Adit - What this error says is that the model was created with one set of wizard and the current wizard is a different one. Usually, the assembly and task wizards work together. The tasks in the task wizard are or can be configured based on what was selected in the model wizard. If there is a mismatch, the task wizard won't appear.
Regarding the events not appearing, could you go to File > Load > Preference File , select 'MBD Vehicle Dynamics Tools' and click Load. ? Did that work ?
regards
praful
I have loaded MBD Vehicle Dynamics Tools but still no 'Ad events ' option is there.
In the attached image vehicle tools option is there in menu which means MBD vehicle dynamics tools is loaded but no 'Add events ' is there.
Did you create the vehicle model from the existing wizard library, or did you create this from scratch? One thing I have noticed in your screenshots, is that the icon for 'Altair Driver' does not look like a driver's helmet. Also, the modeling entities for the 'Altair Driver' do not get exposed to the user when everything is set up correctly.
I have created the model using user/custom library with its wizard file.
There is likely some incompatibility between your user/custom wizard, and the way the default library model/events work. I would suggest that you study how the default library and event topology is configured, and use that as a pattern for designing your own custom wizard. There is specific code (and logic) for how the events communicate with the vehicle models. If you do not match this logic flow in your custom wizard, the events will not know now to connect to your custom models.
