I'd like to perform a PSD analysis using NCODE.
I have performed a modal FRF using Optistruct but in NCODE is not able to consider the results as FRF.
Do you know why?
I will check and update to you soon.
Hi @bmech
Which version of Ncode are you using?
12.0
@bmech
Are you trying to use .op2 or h3d file in Ncode?
Do you see any error message?
Please use DesignLife v13.0. Some interface update with OS is only available in v13.0.
