Internal error, "addacol.F"
Altair Forum User
Altair Forum User
Hi everybody,
I am trying to optimize a wheel carrier using OptiStruct (HyperMesh v14.0). Unfortunately, the simulation stops after the 9th iteration and I receive this error:
*** INTERNAL PROGRAMMING ERROR ***
   in file 'addacol.F', at location # 59.
       ioerr(1) =     652858
       ioerr(2) =     650580
       ioerr(3) =     652862
       ioerr(4) =          8
       ioerr(5) =         17
 ****  ABORTING RUN DUE TO AN INTERNAL ERROR  ****
In a previous optimization, which worked just fine, I used contacts between the blue bracket the red part (non-designspace) and the grey part (designspace) but did not receive a proper result. For this reason, I switched to connectors (bolts) and created two of them in the holes. This model is more accurate than the first one. I did not change any other parameters etc.
Can you help me finding my mistake?
Thanks in advance,
Pano
  • Altair Forum User
    Altair Forum User
    edited February 2017
    Apparently I fixed the problem. I did not change anything but it worked the third time I tried to run the optimization.
    Kind regards,
    Pano
  • Altair Forum User
    Altair Forum User
    @Pano
    Strange.. :mellow:/emoticons/default_mellow.png' title=':mellow:'> and thank you for the update... :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
