I want to simulate a rivet Joint just applied shear force. Between the rivet and the hole in the metal Sheets is a gap.
I get convergence but the rivet turns a Little. u can see it if u watch the displacement Contour plot on the rivet which is not symmetric. Is that because of the coarse mesh?
I tried to use gap elements but maybe i put some wrong Setting.
attachted are the model. Can anybody help me to fix the Problem?
