INTERNAL PROGRAMMING ERROR # 8011 & #8008
User: "Atul Yadav_20380"
Altair Community Member
Updated by Atul Yadav_20380
I ran into the problem of INTERNAL PROGRAMMING ERROR # 8011 & #8008.
I ran the same exact run and it got solved. Now I am facing the same issue randomly. Sometime the run get the h3d and somtimes it gets the error. even after the non linear solution has been converged.
1 - 1 of 11
    User: "yuhaohe"
    Updated by yuhaohe
    What version of OptiStruct are you using? Can you try the latest version 2020.1?
