Hi sir,
*** ERROR # 1009 *** in the input data: Multiple 'MOTION' cards in SUBCASE # 1.
Thanks & Regards
Ramesh
Ramesh,
Provide more details about analysis and provide .out file.
I cannot make out anything from .out file. Provide more information.
If possible share the model file.
I am able to run your file without any error msg as it is.
If you are interested in doing a Multi body simulation, you can use MotionView, MotionSolve instead of HyperMesh and OptiStruct.
i just run the file i m getting error as
*** ERROR # 1482 *** Field 1 contains incorrect characters or embedded blank(s).
*** Run terminated because of error(s) in the input data.
Please share the the version of HyperWorks you are using and their updates.
It works fine with HW 14.0
Please go to Help in HyperMesh > Updates and System Information, and please send a screenshot
