hi ,
I got this error when i tried to work on the tutorial for fluid-structure coupling . Can anyone explain y this error.
'set1 referenced by displacment card not found'
Hi nnav,
Have you created any output request for displacement which refers to node set?
can you remove that particular output request for displacement and check if you are thru?
@ PRAKASH PAGADALA
yes i did create an output request for a node set. Sure will try removing it . And thanks for the suggestion
