Explicit analysis with RADIOSS
Hello everybody,
I've read the tutorial on RADIOSS like the 3 point bending and i just try to simulate something simple to apply the things learned. Unfortunately in my excercise there is something wrong. I simulate two rigid cubes which move in a box. I use all shell element and an elastic material. RADIOSS give me back a lot of errors, from a wrong formulation of the input function for load to an invalid definition of rigid body. Can someone help me?
Hi Alessio,
Please try with the attached model.
Changes Made:
The element types were updated in the model.
The functions defined were modified and the same was recalled in the gravity load created.
0 -
Thanks George,
I have just some questions about the tool:
1. Is the g load the results of the multiplication between curve values (in my case 0.65) and scale X (in my case 9810)?
2. Use rigids which connect all nodes of a rigid body will affect the behaviour of that body under gravity load?
0 -
Hi Alessio,
1. Yes, the curve value will be the product of Scale X or Y and curve.
2. No, it will not affect. Ensure all nodes are selected including the rigid body master node.
