I'm trying to do a composite optimization following the tutorial that described a monocoque FSAE optimization , Material; I use aluminium honeycomb 20 mm and carbon fiber 0.4 mm . I want to optimization only face sheet on sandwich panel and core have thickness 20 mm in the center how should i do.
Thanks,
