How to check contour plots in AcuSolve?
AcuFieldView is a dedicated CFD post-processor that is designed only for use with results that were generated by AcuSolve. AcuFieldView can be launched from within AcuConsole, or launched as a separate application from a Start menu shortcut or via the command line.
