Do you have /PROP/TYPE9 (Orthotropic Shell Property) in your model?.
If so, edit (Right click on Blank property and select card edit) the blank property /PROP/SH_ORTH card and specify dummy values for Vx, Vy and Vz as shown below and try running the same.
