Hi every one !
I have difficulties resolving a tank decompression problem...
I have a tank full of air at pressure P1 at t=0.
At t=0.2, the tank is open to the outside at pressure P2<<P1.
Analytically, after 1 sec, pressure of the tank is still far from outside pressure...
So, on Acusolve, I did one volume with one outlet only. I put P1 value on pressure in Nodal Initial Condition and I created a multiplier function in order to get my outlet pressure equal to P1 before t=0.2sec, then drop down to P2<<P1 after t=0.2sec. I run the calculation for 1.2 sec.
But the result show me that pressure inside the tank is folowing instantaneously the outlet pressure, which is absolutely not physically correct...
I think that I miss some parameters somewhere, but I don't know where...
Is somebody has any idea to help me ?
Thanks a lot !
