In one of the semminar viedo it has been mentioned that the geometry can be exported from Flux2D and imported to FluxMotor Part Library.
   I have tried doing this using a .STEP file type but I am geeting folowing error while trying to import in FluxMotor Part Library:
   com.cedrat.motor.motorcommon.common.error.FmSystemWarning: UserInnerMagnet - Following parts couldnt be loaded :      D8_Geometry.STEP : D8_Geometry.STEP.xml file is missing#100.16.6, D8_Geometry.STEP.part file is missing#100.16.6, D8_Geometry.STEP.xls file is missing#100.16.6 #100.16.12 at com.cedrat.motor.motorcommon.common.error.FmErrorManager.createSystemWarning(FmErrorManager.java:902) at com.cedrat.motor.motorcommon.model.librarycatalogmanager.filemanager.ItemContainerFileManagerAbstract.loadItemContainerManageWarnings(ItemContainerFileManagerAbstract.java:116) at com.cedrat.motor.motorcommon.model.librarycatalogmanager.filemanager.LibraryFileManager.elementToLibrary(LibraryFileManager.java:320) at com.cedrat.motor.motorcommon.model.librarycatalogmanager.filemanager.LibraryFileManager.loadItemContainer(LibraryFileManager.java:113) at com.cedrat.motor.motorcommon.model.librarycatalogmanager.filemanager.LibraryFileManager.loadItemContainer(LibraryFileManager.java:79) at com.cedrat.motor.motorcommon.controller.librarycatalogmanager.datamanager.ItemContainerDataManagerAbstract.getItemContainerFromXmlFile(ItemContainerDataManagerAbstract.java:597) at com.cedrat.motor.motorcommon.controller.librarycatalogmanager.datamanager.ItemContainerDataManagerAbstract.getItemContainerFromXmlFile(ItemContainerDataManagerAbstract.java:584) at com.cedrat.motor.motorcommon.view.librarycatalogmanager.details.selector.panels.SelectorPanelAbstract.updateSelectedItemContainer(SelectorPanelAbstract.java:712) at com.cedrat.motor.motorcommon.view.librarycatalogmanager.details.selector.panels.SelectorPanelAbstract.updateFilter(SelectorPanelAbstract.java:683) at com.cedrat.motor.motorcommon.view.librarycatalogmanager.details.selector.panels.SelectorPanelAbstract.access$200(SelectorPanelAbstract.java:93) at com.cedrat.motor.motorcommon.view.librarycatalogmanager.details.selector.panels.SelectorPanelAbstract$ItemSelectionTreeSelection.valueChanged(SelectorPanelAbstract.java:649) at javax.swing.JTree.fireValueChanged(JTree.java:2927) at javax.swing.JTree$TreeSelectionRedirector.valueChanged(JTree.java:3391) at javax.swing.tree.DefaultTreeSelectionModel.fireValueChanged(DefaultTreeSelectionModel.java:635) at javax.swing.tree.DefaultTreeSelectionModel.notifyPathChange(DefaultTreeSelectionModel.java:1093) at javax.swing.tree.DefaultTreeSelectionModel.setSelectionPaths(DefaultTreeSelectionModel.java:294) at javax.swing.tree.DefaultTreeSelectionModel.setSelectionPath(DefaultTreeSelectionModel.java:188) at javax.swing.JTree.setSelectionPath(JTree.java:1634) at javax.swing.plaf.basic.BasicTreeUI.selectPathForEvent(BasicTreeUI.java:2393) at javax.swing.plaf.basic.BasicTreeUI$Handler.handleSelection(BasicTreeUI.java:3609) at javax.swing.plaf.basic.BasicTreeUI$Handler.mousePressed(BasicTreeUI.java:3548) at java.awt.AWTEventMulticaster.mousePressed(AWTEventMulticaster.java:279) at java.awt.AWTEventMulticaster.mousePressed(AWTEventMulticaster.java:279) at java.awt.AWTEventMulticaster.mousePressed(AWTEventMulticaster.java:279) at java.awt.Component.processMouseEvent(Component.java:6530) at javax.swing.JComponent.processMouseEvent(JComponent.java:3324) at java.awt.Component.processEvent(Component.java:6298) at java.awt.Container.processEvent(Container.java:2236) at java.awt.Component.dispatchEventImpl(Component.java:4889) at java.awt.Container.dispatchEventImpl(Container.java:2294) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4522) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466) at java.awt.Container.dispatchEventImpl(Container.java:2280) at java.awt.Window.dispatchEventImpl(Window.java:2746) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758) at java.awt.EventQueue.access$500(EventQueue.java:97) at java.awt.EventQueue$3.run(EventQueue.java:709) at java.awt.EventQueue$3.run(EventQueue.java:703) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86) at java.awt.EventQueue$4.run(EventQueue.java:731) at java.awt.EventQueue$4.run(EventQueue.java:729) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:728) at org.netbeans.core.TimableEventQueue.dispatchEvent(TimableEventQueue.java:159) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93) at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
   Is there any other way of doing this?
   Stan
