I am trying to run a linear static analysis which has 36 loadsteps. I need to apply these loadsteps in sequence and need the results from the previous step to be retained for the next step. I am trying to use the statsub(preload) card but it gives an error that subcases cannot be nested. What is the right way to do this in a linear static analysis.
Hi Swapnil,
Have you tried CNTNLSUB?
The CNTNLSUB is used to continue a nonlinear solution from a preceding nonlinear subcase, and thus create complex loading sequences.
Please note that this works with non-linear solutions. So you can start with NLSTAT instead of linear static.
I would also suggest you to go through CNTNLSUB comments section on OptiSrtuct help for more information about the same.
