How to delete an entire component to pursue the calculation
User: "Altair Forum User"
Updated by Altair Forum User
Hello everyone,
For the first time we are working with series of radioss files.
At a given time of the calculation , for example at t=10s, we would like to continue the calculation by deleting a component. The reason is that this componenet is RDX gaz and is causing problems at the interfaces at a time he is no longer important in our model.
In the HELP documentation we found that it was possible to delete a defined set or list of elements, but we are trying to delete an entire component, If any one could help us please !
In the new file of calculation  _002.rad we want to use /DEL/????? for example like  /DEL/Component
1 - 1 of 11
    OP
    You can delete the elements belonging to that component in the second engine file using /DEL/Eltyp/1 command.
    Specify the first and last element number of a range to delete so that the entire elements in that specified range will be deleted.
