I have a model that includes PCOMPs and I have already ran the free-sizing optimization. After opening the second file and transforming the derived STACKs and PLYs into PCOMP entities and values, I followed the process as it is described in the tutorial, but after output there exists an error message stating that there is no 'T10' field in the property card, which is impossible, because it is included in the output file. I have 6 PCOMP properties with approximately 50 layers each of them. The error message concerns the DVPERL1 card where after 9th layer's thickness there seem to be an unavailability to get the value from the 10th layer.
Can you suggest me anything about overcoming this problem? I hope you can answer my question as soon as possible.
Best regards,
Christos
PS: It is vital not to change the model properties from PCOMPs to STACKs and PLYs
