Altair RISE
Nominate Yourself Now!
Error Running an FEA
User: "Altair Forum User"
Updated by Altair Forum User
I am trying to run an FEA on a truss section. The setup is that it is supported on both sides, with a 937.5 psi load distributed over a 4' by 4' square. After I went through the setup following a tutorial, I tried running it and it gave me the following error. As of now I put a dconstrain on the magdisp, but I'm not sure if that was right. I'd appreciate any help. I have attached the file below.
Messages for the job:
 *** ERROR # 1908 ***
 Case Control data LOAD=2 is not referenced by any bulk data
 relevant for used subcase type.
 *** Run terminated because of error(s) in the input data.
Thanks!
Neel
