I wish to use the Dominant Path Model at higher frequencies. How should I modify the settings under the Computation tab?
You may want to adjust the interaction loss value in the DPM parameters.
The default value of 13 dB is valid for the 2 GHz band and should be adapted depending on the frequency of interest.
As a rule of thumb the interaction loss increases by 1-2 dB when you double the frequency, e.g., from 2 GHz to the 4 GHz band.
Similarly it goes down when you reduce the frequency.
