Dear Sir,
I am analysing a cylinder that is symmetric every 1/10 of 360o. I therefore consider only 1/10 of the cylinder (image of the part is attached).
I want to create cylindrical coordinates and use them to constraint the angular displacement (theta) on the surfaces that are been cut from the original cylinder.
I therefore create a cylindrical coordinate system and constraint the DOF2 (correct?) on these surfaces.
Is it possible to then apply force in the original cartesian coordinate system (not the cylindrical one)?
From what I understood I should specify which nodes have to be in cylindrical coordinates and which in cartesian.
What if I want to apply the force in cartesian coordinates on the same nodes that I want to constraint in cylindrical coordinates? Is that possible?
Thank you in advanced
