hello,
sometimes after the analysis it is not showing as job completed but # symbol occurs there. what does it mean.is there any missing or alteration of results will be there due to that.
Hi @jahnavi
In the attached .out file I can see Analysis completed at the end. Is it the same out file you are referring to?
yes.in the top it should show as job completed.so is it not a problem??
@jahnavi
No problem unless you see any error messages.
