Composite Wheel - Closed thin wall section
Altair Forum User
Altair Forum User
edited November 2020 in Community Q&A
I am trying to create a laminate for curved closed thin wall section. The cross section has been split up into different components because of the way the part is designed. In the design the layup changes in different parts of the cross section, and in this method I could group elements according to selector so I can assign elements to different plys. I am having trouble creating the laminate.
I was wondering if I could get some help create a laminate with the shell mesh as the outer most surface. When I try, I get the laminates to build on top of the shell and there is no continuity with the elements at each corner. There also seems to be an error regarding element normals.
Thank you !
