geometrical Non linear static analysis on Ti-alloy having cross structure using optistruct
Altair Forum User
Altair Forum User
edited November 2020 in Community Q&A
hello to forum members,
Problem encountered by solver: Fatal error encountered.
About structure: Stucture - Cross
material : Ti alloy
using MAT1 and MATX
Property: PSolid and Psolidx(when using it, error is coming)
Load collecter: NLPARM is used
MY questions
  1.  is my way of solving  correct?
  2. which type of non-linear analysis is required (implicit or explicit) in such structures?
  3. what is meant by fatal error occurred and how to remove it?
  4. For CTETRA elements, Isolid (in psolidx) is not provided any value. does it means it has to keep off and other parameters such as imsrtr and icpre and iframe has to provide some numerical value? if so then what values should be chosen and why?
  5. there is no tutorial for solving such problems with Radioss. hyperworks help is not regularly updated
  6. In Matx card, is it necessary to provide values to all the parameters like a, b, c, epsmax, N, sigmax?
I am uploading .hm file with the issue.
I need sincere assistance as this would help me completing my research work.
Thanks and Regards
  • Altair Forum User
    Altair Forum User
    edited March 2017
    Hi Ashu,
    1) Are you using NLSTAT as analysis type? If yes, then PSOLIDX, MATX, cards are not compatible with NLSTAT. Instead use MATs1 to provide non-linear parameters.
    2) Type of non-linear analysis depends on loading, event time etc...
    4) For NLSTAT you don't need PSOLIDX
    5) There are tutorials available on NLSTAT, NLGEOM (non linear implicit) on OptiStruct help
  • Altair Forum User
    Altair Forum User
    edited March 2017
    hi Prakash,
    i am not using NLSTAT for this.
    I am using NLGEOM analysis type.
    please have a look at my .hm file
