i tried to retrieve the eigen values in modal FRA analysis in optistruct solver. But the eigen values are not retrieiving in FRA step from modal step.
Hi Sai Kiran,
What is the command you are using to retrieve the eigen vectors
Also make sure the Eigen Save is in the same folder from where you are running the job
Thanks,
Vikas
