Hi Prakash Pagadala
I have faced a problem in the optistruct. after doing a modal analysis. analysis is completed but I get this result
1 Error: Unable to locate /gear analysis/modal ****.h3d model file.
Check for h3d file in run directory.If it is there then you can directly load h3d file in Hyperview.If it has error it would be available in .out file.Please share same.
