when we create a card for rbody on or rbody off we have to add the master node id of global rigid and other rigids.
I am little bit confused about the node ids.
Which node id to be added in rbody on and which in rbody off?and why?
Hi Raju,
Please go to RBODY Manager in HyperMesh and choose the master node id.
Based on the rbody id selected the rigid body will be on and off for the prescribed run time.
Please go through Example 12 - Jumping Bicycle in the Help Menu where these options are used.
