In Radioss after the completion of Analysis results are not displaying in the solver folder, it doesn't create animated files to see results.
Only below-mentioned files were created.How can I see the results with hyper view.
Please share the engine file (model_0001.rad).
I attached the engine file, please take a look
Can you remove the negative sign in time(ANIM_DT and run time) in the engine file, as it cannot be negative and rerun.
Also share 0001.out file
Please try running with the attached engine file.
I attached the mode0001.out file, take a look
After running the file which you attached I got below mentioned error.
If you don't mind can you give guidlines to run postprocessing in radioss?
Please input these values for run controls in HyperMesh and try running:
RUN time: 0.135
/ANIM/DT:.0027
Postprocessing the RADIOSS results is done in Altair HyperView. You can upload the .h3d created in HyperView and can review the results.
Please go through https://www.youtube.com/watch?v=S02kDguy4dw which shows postrocessing the results in HyperView.
Additionally go through our tutorials in Help where this is also shown.
Thank you, it worked
