Hello.
I'm trying to run Linear Transient Heat Transfer Analysis but I keep getting error 2094. When I apply heat flux on element nodes and try to run analysis this error pops up. It doesn't happen when applying heat flux on the face of element. Is there any possibility to create heat flux on nodes? Could you help me with this error? Thank you in advance.
Best regards
