I have a model with C shaped surface to surface contact as suggested below (red slave and blue master) with a gap of 1mm similar as shown below
This is the setting for which my model converged and analysis was successful.
But upon closer observation, I see that the gap between the contacts is not being closed but stresses are transferred.
After understanding a bit about 'CLEARANCE' ,
I don't think to give a clearance value more than gap is a good idea.
Please provide a clearance value of say 0.7 and check if that helps.
