Is it possible to get the value of Lagrange coefficient (lambda) at the end of constrained optimization in optistruct? (in particularly size optimization)
I want this values because it will give you important clue for solution of optimization problem.
It is possible to fetch this values at the end of optimization in MATLAB, So may be there is some way to fetch this values from Optistruct as well.
