I am trying to do modal analysis of a leaf of a leaf spring. The leaf spring needs to be provided some rotational stiffness at the end.
I have basically connected the eye of the leaf through RBE2 to a single point which in turn is connected to a CBUSH element to provide rotational stiffness.
However, my model is not showing any change in modal frequencies(i.e. no stiffness added in rotational direction) even though i am using 'RIGID' stiffness.
Can you please clarify why it is happening like that?
