While giving MON_VOL for tyre this error pops up
Can you please help
Please share the starter out (_0000.out) file.
Sir the file is aatached here
This seems to be an issue with the surface created for defining the monitored volume. The airbag external surface should be built only from 4- and 3-noded shell elements. The airbag external surface cannot be defined with /SURF/SEG, or with /SURF/SURF.
Create it using /SURF/PART, recall the same in /MONVOL/GAS and try running.
You can see these steps in https://altairuniversity.com/learning-library/airbag-simulation-setup-in-radioss/
