Does Optistruct have revolute joints setting example?
I am practice non-linear static in Optistruct.
I want to know how to set the revolute joints.
I have seen the RD-4000: Dynamic Analysis of a Three-body Model using RADIOSS in HyperWork10, but I can't find it's file.
And I hope the example is used by Optistruct.
@Prakash Pagadala Thanks to your apply!
I have use your suggest to do the example at other article and I have marked you.
Really thanks to you!
0 -
I do not understand what the Coordinate Systems are for?
first grid and second grid are the nodes to connnect with the revolution joint i believe.
But how is the axis for the rotational freedom defined and what reason have the GID1 and GID2?
Could somebody please explain this real quick. My analysis does not work out.
Thank you
0 -
Please take a look at JOITG documentation at OptiStruct Help section.
There's also an example that could be found under the examples section.
GID1 and GID2 define the connection points (nodes connected by the joint).
CID is the coordinate system that defines the joint orientation.
0 -
example model found in the documentation.
0 -
Thank you!
