Topology Optimization with fully stressed design
Altair Forum User
Altair Forum User
is it possible to run a topology optimization maximizing the von-Mises stresses to a state of a Fully Stressed Design ?
I want to optimize a reinforced concrete beam under a given load.
The respons should be to minimize the mass/volume by optimizing the concrete towards its main compressive stress (reaching a Fully Stressed Design). Is this possible by using the stress constraint definition of optistruct ?
Thanks for your answer.
Philipp
  • Altair Forum User
    Altair Forum User
    edited February 2018
    This should be possible.
    You can provide the stress constraint on DTPL card.
  • Altair Forum User
    Altair Forum User
    Thank you for your answer.
    How would i do that ? My idea was the following setup:
    Optimization Responses: 1 mass, 2 static stress
    Optimization Constraints: response = stress, upper bound = -25 N/mm²
        lower bound = -25 N/mm²
    Objectives: minimize mass
    Would that give me the soulution i need ?
    Thanks again for your help.
  • Altair Forum User
    Altair Forum User
    You can use, but instead, use stress constraint on DTPL (-25) and check if this helps.
