What should be the parameters(eg. SSID, MSID.SRCHDIS) in general TO define the contact interface?
SSID is the Slave entry ID and MSID is for the master.
SRCHDIS is the search distance and varies with the type of contact.
Thankyou for reply
Please can you guide me how can I get SRCHDIS value for slide, freeze and stick contacts
Hi Aditya,
PFA from OptiStruct help:
