Hi George,
What is the reason that I can't see vonMises, spec. Energy in my disc. It works for the tretra elements. Only the displacement contour works. You can see it in the images ( ). I also attached an image of the engine cards () I used.
Thanks, Best
J
Hi Jonas,
Please keep /ANIM/ELEM/SIGX, /ANIM/ELEM/SIGY, /ANIM/ELEM/SIGZ, /ANIM/ELEM/SIGXY, /ANIM/ELEM/SIGYZ, /ANIM/ELEM/SIGZX, /ANIM/ELEM/VONM in the engine file and try running.
If the results are still not extracted please share the model file.
I tried. Still did not work. I'll share you the rad file:
Thanks for your help!
Best, J
Please try with the attached files.
Hi Jonas, Please keep /ANIM/ELEM/SIGX, /ANIM/ELEM/SIGY, /ANIM/ELEM/SIGZ, /ANIM/ELEM/SIGXY, /ANIM/ELEM/SIGYZ, /ANIM/ELEM/SIGZX, /ANIM/ELEM/VONM in the engine file and try running. If the results are still not extracted please share the model file.
Hi George
For strain is it ANIM/ELEM/STRZ .....
For plastic strain you can add /ANIM/ELEM/EPSP in the engine file.
And for shell elements you can add /ANIM/SHELL/TENS/STRAIN/ALL and for solid elements /ANIM/BRICK/TENS/STRAIN/ALL can be used.
Thank George
But for the 2D plain strain your keywords do not work. Do you have any suggestion for me?
There are some limitations for plane strain problems in RADIOSS. For strains you can only extract plastic strain (/ANIM/ELEM/EPSP) for plane strain problems.
