Is super elements supported in Radioss?? any tutorials??
Hi Guru,
Multi-Domain is a similar approach in RADIOSS. The objective of the multi-domain (also called RAD2RAD) is to optimize the computational times of large models characterized by different mesh sizes and consequently very different time steps. The principle is to isolate in a global model a set of subdomains (/ SUBDOMAIN) whose mesh size deviation is sufficiently large, so that each of these subdomains is computed using its clean no time.
Please go through Example 45 - Multi-Domain in the Help Menu which shows Multi-Domain technique. Model files are attached for your reference.
