HI, i was wonder is it possible to export a tcl file or txt file from a HM model that i have created? such as a file that shows all the command and step and detail of how i create the HM model.
By default, all your commands were saved within 'command.tcl'
how can i export a command.tcl file in a prepared template of HM?
You don't need to export it, it is locating in folder C:/users/..../documents
or, open command window of hypermesh (menu View>Command Window) and type 'pwd' , press enter
command.tcl is there
