I am trying to use the viscoplastic model based on overstress.
For certain parameter combinations, when i run the forward homogenization simulations, i keep getting the warning: "Jacobian of gamma function is equal to ZERO". The simulation freezes and cannot be solved.
Below are the screenshots of the parameters and simulation i am running. Only simulation 5 is being used for the forward homogenization.
What does this mean?
How should I adjust my parameters to avoid this warning?
Layup ID 2 corresponds to 11 90-degree plies with nominal thickness of 0.315mm.
Any help or suggestions is appreciated.
