I m getting this error while solving
*** ERROR # 24 *** Eigenvalue SUBCASES or acceleration loads exist, and the total mass of the model is zero or negative. Please check the material data, the mass defined on element/property.
Hi Ramesh,
check the material data, looks like you didn't provide any density for the material you are using.
Provide density data in material cards and run analysis.
