my name is Nicola ed i've a problem with the contact between a shell and a solid . I've a load distribution on a shell and i want to transmit them on the solid (with different mesh). I've done a CONTACT FREEZE, but when i do the static analysis you can see that the shall has a bad behaviour (master is the shell and slave is the solid). I tried to increase the thickness until 1 mm; this improved behaviour of deformation but doing that we are increasing stiffness of the system and decreasing displacements.. i expect thant the shell is completely attached to the surface of the solid so without compenetration or something..
Thank you for your help.. i need it.
Nicola
