Dear all,
This is my first post, if it is not in the good forum please excuse me.
I am trying to set up a program written in TCL to generate MPC equations with specific nodes that will have been selected by the user.
I managed to create a variable which reference all nodes IDs that I need to generate the MPC. Example: $UniqueList is the variable that contains these values associated to nodes (3 of them here) IDs: 2 3 47.
This is an example of script for an MPC generation of 3 nodes connected to 1 master node:
*createmark nodes 1 33-35
*createarray 3 13 13 13
*createdoublearray 18 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23
*equationcreate 1 1 3 1 18 85 5 1.23 5.0
The PROBLEM:
My list of nodes ID will be random and therefore the problem is that the command ' *createmark nodes 1 $UniqueList ' doesn't work because the program doesn't read each value as it is and therefore I get a problem in the equation.
I would be very thankful if someone could give me the right script to use to create the mark for the nodes. Thanks in advance.
