Hello everyone
 	I'm trying to simulate a segmented magnetic bearing and the thing is that when im trying to solve the scenario it shows me this:
'The group of volume regions:
 	   - TAPA
 	is multiply connected (have hole(s)).
 	There can be a problem called connexity problem if a coil forms
 	an interlacing with the group of volume regions.
 	If you have a connexity problem, you must create a cut of
 	magnetic circuit which cuts the group
 	of volume regions.'
   	The thing is: ¿How do I repair this problem?
