Dear All,
I want to calculate press in force required to push the bearing outer ring into the housing using pressing dolly.
I have defined contact between pressing dolly and outer ring; outer ring and housing.
Is that pressing force is contact force between pressing dolly and outer ring ??
Need your opinion for the same. (I’m using Radioss for this analysis)
Also, Is it possible to do above analysis at -30 degrees surrounding temperature?
Please revert with the above queries.
