I have an antenna design with circular polarization, both co- and cross-polarization patterns were designed in CST and I want to test it in an indoor model in WinProp. However, as far as you know, WinProp only takes linear polarization when it performs the propagation testing. Should I just import them as RHCP and LHCP or convert them into theta and phi components instead, however in this case I will lose the 90-degree phase shift between them.
In fewer words: What is the best way to do circular polarization in WinProp?
