how can i write out a triaxiality factor with radioss? I can't find any output command.
Best regards
To calculate stress triaxiality request stress tensor output in the engine output,
/ANIM/SHELL/TENS/STRESS/ALL
and then you can use HyperView to post process the results and HyperView will calculate the triaxiality from the stress tensor results just like it can calculate Von Mises stress.
Thanks,
Andy
Thank you!
