Hi all,
I am using NX-Nastran as solver. Pre-processing done in Hypermesh.
When solved on NX-Nastran(10.0) getting error as 'Results not found'
Imported .bdf into Nastran and solved.
Hi Naveen,
Please contact NX-Nastran support.
Its a problem often araising in NX NASTRAN. It is because of the following possible reasons.
1. Check working directory is accessible
2. Open NASTRAN by 'Run as Administrator'
3. Verify whether the BC's are correct
4. Verify whether there is a problem during importing or exporting in Hypermesh. If so, Rectify immediately
