Hi, i'm running an analysis. The analysis is looked like boil the water. I've tried following the tutorial such as OS-1080, OS-1085 and OS-1090. In my model, the pot was heated from the bottom, and the objective is i want to know the temperature in the whole side of the pot, and also temperature of air inside the pot. The problem is, how can i load the temperature of heat source at the bottom of the pot? because i've tried to put the SPC in the top of the pot.
I hope someone can help me with this.
Edo
